Whiteboard Collaboration | Community
  • July 19, 2022
  • 12 views
I am struggling to find away to invite external guests to our organisation join us on a white board.
Says our settings are set that way, I am the admin and cant work it out!
Any advice please!
Best answer by StephenNewton
Hi, I have a Pro account, I am the owner there is no one else. Why am I not the Admin?
It says admin has disabled
How do I enable whiteboard sharing to Anyone?
Thank You
@AskTony
Please take a look at this response I put here where the settings for controlling access to whiteboards are found in the admin settings. If you're in the owner of the account, you should able to adjust these settings:
https://community.zoom.com/t5/Whiteboard/Whiteboard-Sharing/m-p/118655/highlight/true#M920
Hope that helps!
crchan123
Hi @CherieCanning! Welcome to the Zoom community, we're happy that you're here 😊
There are two options to invite others to collaborate on your whiteboard.
  1. Click Share to invite other users to collaborate on the whiteboard. Enter the contact names, zoom chat channel, or email addresses of the users you would like to share the whiteboard with and set their permissions with the arrow to the right of the entry box. Click Share to finish.
  2. To create a shareable link: Click the arrow to the right of the Copy Link button
    at the bottom of the window to set the permissions for users you are going to send the link to. Click Copy Link and then paste the link in a message or email to send to others.
Do any of these methods of sharing work for you?
No this does not work.  How can I share a whiteboard outside of my organization?
@bfairley - ok so if that's the message that means that the owner of the board has the following permission unselected. You can find this setting by clicking the "Share" button on the board (but the board owner will need to be the one to enable it).
Thank You
I'm having the same problem.  Where did you find that setting option?
