Events Registration Information with answers to custom questions | Community
  • April 3, 2024
  • 15 replies
  • 1 view
I can't find the registration custom question information for the event. Where would I find that?
I downloaded General Ticket Registration which doesn't have that information. Once in a while, that CSV file has no information. I saw it one time couple of days ago, and now it is missing. Please can someone help. Chatbox isn't helpful either. The event is in 3 days and I don't have the complete data yet. Any help is appreciated. I feel like it was a mistake of using the zoom events. I should have gone with regular webinar.
Best answer by ZoomEv1
I think the system glitch has been fixed now. I can see the data, but it was too late as I had to manually work with the data one by one as my event is today. Too late for me. I wish there was a some sort of notification or an acknowledgement and it took a week a solve such a simple and very important issue.
I just want to share - I am having the same issue and there are N/A placeholders where I need to have the data we asked for.  Zoom Events is a mess.
imogenraynerae
Hi @ZoomEv1  and @miketino
Here's how to find the answers to Custom Registration Questions from your attendees:
1. In Zoom Events, scroll down to Analytics on the left-hand side.
2. Then select 'Custom Report'
3. Then Click 'Create Custom Report'
4. From the drop-down select 'Registration Question for Ticket'
5. Follow the next 2 drop-downs, selecting an option for each. It doesn't matter what you select as the csv file that is generated will give you all the data from your Custom Registration questions even if you only selected one option.
6. If you get a 'Filter by text' option just enter any letter e.g 'y'
7. Click 'Create Report'.
8. The csv file will then be downloaded to your PC and will contain all the Custom Registration data.
This is one of the quirks of Zoom Events. I had the same frustration and I hope this helps you. If not, let me know, and I'll produce a short video to show you.
I hope your event goes really well.
Best wishes,
Imogen Rayner 😁
P.s Some attachments to help you
 I am trying to find the results of my custom registration questions.  My left side menu does not have any of the items that you have you file.  I don't see overview or Analytics on the left hand side.
Please help, my event is Wednesday.
Barbara
ZoomEv1Author
Thanks for your response. I apprecite your help. But I don't see the step 4. See the screenshot. Any help is appreciated. I couldn't attach the image, but here is the link for the screenshot: https://ibb.co/SrFjKss
Thanks.
imogenraynerae
Oh I can see why you're finding it frustrating. Have you tried registering for your own event? It's a good way to check its set up right. Feel free to post the link here and I can register and check its working.
ZoomEv1Author
I did register and I was able to download with the data two days after setting it up. Now, the data is showing empty. Here are the screenshots showing that the survey responses are part of the download: https://ibb.co/Zc47VRy and second one showing that the mandatory questions (* on the header) coming up with N/A: https://ibb.co/zZtWvzJ  Any help is appreciated.
imogenraynerae
Okay - There must be a setting wrong somewhere. Can you confirm whether its data from a standard registration question or a custom registration question you're looking for?
I just want to check we're absolutely looking for the same issue.
Imogen - I welcome connecting with other Zoom Users - you can learn more about me here.
ZoomEv1Author
Responses to custom questions are completely missing along with responses to some of the standard questions.  So, both are missing.
I don't want to hijack this thread, but I also had trouble getting my custom registration questions to show up in the standard report -- a week ago they did show up in the standard report but today they don't. (They also showed up in the standard report 2 months ago when I had a different Zoom Event running at that time.) So something has changed and not been documented, or this is a bug.
After searching around Zoom.us I found this forum post and I was able to follow the instructions imogenraynerae indicated above to make a Custom Report and voila the answers to my custom registration questions showed up.
However, according to Zoom's own Knowledgebase documents, these answers are supposed to be in the standard "General Ticket Registration" report.  At least for me, last week (and prior to then) the answers were actually in that standard report. Now there is a column in the standard report containing my custom question but every entry says "N/A" which I knew was incorrect as last week my test account, which had answered the questions, did have data in that column.
So I wonder if there's some hanky-panky going on behind the scenes at Zoom and they aren't fully aware of the consequences to the end-users.
In any case, I do see "Registration Question for Ticket" in my dropdown  as per the attached photo.  I wonder if you maybe could find someone in Zoom Tech Support to look into it b/c it definitely seems to me that some kind of functionality has changed since 1 week ago... Maybe your account in particular has gotten stuck or affected by some back-end change? Just my 2 cents. Sorry I can't be more helpful.
imogenraynerae
Hi @LeeZoomer, You're welcome to join the conversation. Thanks for this—it's good to hear different viewpoints and experiences. The data has definitely moved a couple of times, and I think you're right—there's a glitch in there somewhere. Hopefully, Zoom can fix it soon. I'll report it to them, too.
imogenraynerae
Okay, I understand.
You can check the registration questions are being answered by doing the following steps:
1. Go to the 'Manage Registrants' tab under 'Registration and Join'
2. Click 'Orders'
3. Select an arrow next to an attendee on the right hand side
4.  Then click 'View Registrant Details'
5. All the info should be in there so you know its being logged.
In the Analytics tab if you've checked all the 'standard reports' in the 'Registration & Ticketing'  tab and looked in 'Custom Report' then it has to be a Zoom glitch and I would raise a ticket with them flagging it as Urgent. I appreciate this is a frustrating situation.  Do you think you have checked all of these? Keep me posted with how you get on.
Oh thanks for explaining how to get the information for individual attendees in the View Registrants Details in the Orders tab. I never knew that was there.
Just to be clear -- I am able to see the answers to my Custom Registration Questions once I run the custom report as you explained. I just know that information used to be in the standard report and now suddenly is not. Hopefully everyone will get to your post that explains how to get the info from a Custom Report which seems to be a valid work around for me.
It does seem like the OP (ZoomEV1) is having a problem creating the custom report.
ZoomEv1Author
Yes, I'm having the problem of creating the custom report as this "4. From the drop-down select 'Registration Question for Ticket'" doesn't show up in my case. Is there anything I need to change in the settings or something like that to get that enabled?
ZoomEv1Author
Thanks for the response. Yes, steps 1 through 5 shows me the data. I can see individual data for each of them. But it doesn't show up on the download. I will raise a ticket. How do I do that?
If this is too cumbersome you could use APIs to extract the reports programmatically that include all custom fields. If you are not a developer there is a marketplace app, Salepager, that lets you generate Zoom webinar registration reports automatically.
