Bulk download from Zoom Events hub | Community
  • April 7, 2025
  • 1 view
Hi
I'm looking for a way that I can do a bulk download of all recordings from my Zoom Events Hub. I'm navigating around the Video Management section and cant seem to find an export option.
Appreciate some assistance here 🙂
Thanks
Kristin
Best answer by joshbrage_ZE
@k_palmer
Unfortunately, there isn't a simple way to do this within the platform itself. However you can use the API in this way (lots of customers use this method to extract recordings for external use cases) https://developers.zoom.us/docs/api/events/#tag/hubs/GET/zoom_events/hubs/{hubId}/videos
Hope this helps!
If I may ask, what are you looking to do with the recordings once you get them out of the Zoom Events Hub?
joshbrage_ZE
@k_palmer
Hope this helps!
k_palmerAuthor
Thanks for the reply, Josh. I will check out the API.
Our company policy only retains cloud recordings for 30 days, and the content will likely be valuable for longer than that. So we'll do an export to a long lived file repository.
joshbrage_ZE
@k_palmer makes sense. Also would be worth checking out our brand new Video CMS from Zoom Events. Designed to help continue deriving value from your on-demand content.
https://www.youtube.com/watch?v=lCxdVlDZPmo&pp=ygUaaW50cm9kdWNpbmcgem9vbSB2aWRlbyBjbXPSBwkJfgkBhyohjO8%3D
(Also different user groups can have different cloud recording retention policies, might be worth a conversation with your team, vs paying for additional services external to zoom - plus less hassle!)
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0073040https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0060832
You can bulk download Zoom cloud recordings using Zoom's API. If you are not a developer there is a Zoom app, Salepager, that lets you bulk download Zoom cloud recordings.
