2023-05-17 01:22 PM
In the documentation, it says that here are settings in the Survey tab which allow you to check whether you want a pop-up survey or a link in the follow up email. (see below) There is no "Survey Options" setting in my webinar Survey tab. What am I missing?
Thanks,
Mary
2023-05-17 03:21 PM
You have to create the Webinar then go in and edit to get the Survey options below
2023-05-18 06:19 AM
Thanks for the reply. My webinar is scheduled and all set up. Could it be something else?
2023-05-18 08:09 AM
Check with your Zoom Admin to confirm that Survey is enabled for Webinar.
Account Management > Account Settings
2023-05-18 12:24 PM
Thanks, Lennie. I was finally able to get the settings to appear. I had to create a survey question and turn on the "follow up email" option. I think it's because if you're not sending follow up email, then it just does the pop-up. But that's just a guess.
Mary
