Webinar Attendee View Can Not Pin 2 or more | Community
  • October 12, 2021
  • 5 views
I am hosting the webinar and when I pin two panelists to be viewed on the attendee view there is still only one view and there is nothing happened. When I pin 3 panelists same, only one is on the screen when I check what attendees view. I tried to set up view follow host view I tried gallery view but it's the same.
Does someone know why this happened and how to fix it to have more people at the same time on the spot?
Thanks.
    Rupert
    Hi @WonderlandAI
    Pin is only your own personal view. You'll want to Spotlight instead - and then enable Attendee View Follow Host's View.
    https://support.zoom.us/hc/en-us/articles/115004834466-Managing-attendees-and-panelists-in-a-webinar
