How to Upload a Recording with more than 50MB | Community
  • April 15, 2024
  • 5 views
when i try to upload a recording with 350MB in the Event Site from Zoom i get the error that the maximum file size is at 50MB. I found in the Guides that the limit should be at 5GB.
How can i get the bigger limit? Or is there a other way to upload content for simulive webinars?
Best regards Alex
    April 18, 2024
    Welcome to the Zoom Community, @JaKo.
    The maximum file size for videos is dependent on where you're trying to load them.  Where, exactly, are you loading to? A screen shot would be great.
    And if possible, a link or a screenshot to the 350MB reference you have.
