HELP!!! Webinar breakout rooms | Community
  • December 5, 2024
  • 6 views
Hi! I will be using webinar breakout rooms for the first time today. I scheduled the webinar BEFORE upgrading to Zoom sessions. I have enabled breakout rooms in account management... just concerned that the breakout rooms wont be there when I start the webinar! Is there any way to test it? I tried a test webinar and maybe because it was just me there, the breakout rooms wasn't showing in the webinar controls.
Do I just have to trust it will appear for me?
It would be better to be able to create the rooms before the webinar starts!
    DeniseLahat
    You can just go in and start the webinar practice session or backstage.  If you are in backstage you need to go to the webinar.  if breakout sooms is enabled in your zoom account settings you should see it.  If you dont see it click on ... more.
