Easy way to Make Zoom Room as Panalist for Zoom Events | Community
  • August 22, 2023
  • 9 views
We are having trouble adding Zoom Rooms as panellists for Zoom events, especially when there are 5-10 Zoom Rooms joining from different countries. As a Zoom admin, we need to have someone join from their laptop first and then pair with the specific Zoom Room before joining the event from the lobby. This process can be time-consuming and troublesome. Often, those working in remote offices lack technical skills, resulting in mistakes during the long process.
Is there any easy way to Join from ZR with one click as a panellist or is there anything on the roadmap for simplifying the process?
    Best answer by bstrelko
    let me try the email address method. Once added ZR via email will there be a join in the controller?
    Yes - just tested this and can confirm.
    bstrelko
    Zoom Rooms can be added as panelists at any time after the webinar is created.
    On the host's account at https://zoom.us/webinar/list#/upcoming, click the webinar title (do not click 'edit').
    Navigate to 'Invite Panelists' and then click 'edit'.
    From here, you can type in any Zoom Room on your tenant and add as a panelist:
    After this, the Zoom Room should be able to join this webinar as a panelist with a one-touch join if the webinar is added to its calendar resource.
    Hi bstrelko,
    It works for regular webinar but not for Zoom Events. There is no option to add Zoom Room as panalist/alternative host in Zoom Events.
    We can add ZR as attendee only.
    bstrelko
    Apologies - missed this detail.
    You can specify the Zoom Room as an alternative host (copy/paste ZR email address from a standard webinar), but there are some bugs to this method - ZR starts in webinar and cannot be moved to/from backstage.
    +1 for a request to get true parity for Zoom Rooms - they're always the last ones to get features that Client gets and are frequently more important in live events!
    Thanks for the helpful guide! Setting up Zoom Rooms as a panelist for Zoom Events was a breeze. The step-by-step instructions really made the process smooth. Now I can seamlessly join Zoom events without any clash in my schedule. Much appreciated
