2025-11-10 06:42 AM
Have been having a lot of issues with zoom at the moment, my account went from sessions to webinars plus and some features were deleted as part of the re-brand. The option to create channels and playlists were there, but now unusable despite me creating a channel before it changed. Moving to a hub which allows me to create the channels and I have transferred past events across to enable me to use the recordings in that hub but some recordings and events are not there now. I have to use the main log in for zoom, go to recordings, download and then upload to a specific hub. This then only uploads a certain view, and no transcripts ect. losing the ability to use smart chapters etc. Is anyonde else having this issue or is there some simple way that I have totally missed?
2025-11-18 09:04 AM
Hi @Jodie1a Happy to hop on a zoom with you to see how i can support
