How to allow Multi-Cameras when running a Teams Meeting from a Zoom Room | Community
  • March 5, 2025
  • 21 views
How can we have the same multi-camera visual that we have during a Zoom meeting for when we utilize Teams in the Zoom Room?
Best answer by bstrelko
You can't, if using Direct Guest Join.
DGJ for Zoom Rooms uses a portable Chromium browser under the hood that takes a single camera (which you can't even choose/switch) and is not a Zoom meeting, so you won't have Zoom-specific functions.
If you use Pexip for Zoom Rooms, you'll be able to add multi-cameras, since an intermediary Zoom Meeting is stood up before connecting everything over to Teams via CVI. However, this solution has plenty of drawbacks as well and your layout, while multi-cam, will be condensed into a single MS Teams participant window.
Sorry to be the bearer of bad news (as of the time of this post), but them's the breaks.
bstrelko
bstrelkoAnswer
Very helpful to know still, thank you
