Display Settings for Portable Companion Zoom Room | Community
  • September 17, 2024
  • 0 replies
  • 0 views
When a Portable Companion Zoom Room is paired with a Dual Screen Zoom Room, where and how can the Default Display Settings be set for the Companion Zoom Room screen?
Meaning, that within the above configuration, when a Screen Share is active in a Zoom Meeting, how can I get the paired Portable Companion Zoom Room screen to display a Gallery View by default?
Is it an additional screen of the Host Zoom Room? If so, then which one?
Through my testing, I have found that when pairing a Portable Companion Zoom Room, the Display Settings that are set within the Zoom Room settings of the Portable Companion Zoom Room are overridden once the Portable Companion Zoom Room is paired with a host Zoom Room.
