entering letter password on phone keys | Community
  • April 13, 2024
  • 23 views
Tried entering letter password with phone keys, using corresponding number for the key.  Didn't work that way.  So how do I enter a letter password on phone keys?
April 13, 2024
hi butlerted,
If the password is used to access advanced settings on the phone, you would select mode and choose from options:
Poly Phones
1 = Abc
2 = ABC
3 = abc
4= 123
Yealink Phones
Access Advanced – Admin Password
Softkey – press these keys to select which format you want.  If abc is displayed and you want, a number, then press this key until you see 123.
abc
ABC
2aB
123
