Zoom Phone Recordings accessible from Admin Log but not from User log | Community
  • February 19, 2025
  • 4 replies
  • 9 views
I cannot access my Zoom Recordings from Personal > Phone > Recordings
But I CAN access them from Admin > Phone System Management > Logs
I am the OWNER of the account and I am the only user.    I have
This is actually causing me to not be able to access these recordings via the API, getting 404 file not found on the recording (which led me to this above - I assume this is related).
I have followed instructions here:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0069655
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0069692
and all settings are set to allow recordings and access recordings.
Please advise.
sparrow
February 19, 2025
Go into your site settings and policy. Check the feature below.
benji800Author
I can confirm this is already set as such
sparrow
February 19, 2025
Can you confirm that you also have the user setting checked as well.
benji800Author
How do you mean user setting?
All 3 checkboxes are checked per your screenshot
sparrow
February 20, 2025
You checked the site level settings, but within each user account you also have the same policy settings that can be enable/disabled. Even though you verified it has been enabled in the site settings, that can differ at the user level if your enabling/disabling policies there.
