Zoom Phone Auto receptionist route to Zoom contact center
M_Ameen
Zoom Partner
Zoom Partner
Can i route auto receptionist to Zoom contact center without a phone number assigned ?
Also can i assign an extension to an IVR without any phone number .
Can someone guide me through this topic. Your help is highly appreciated.
1 ACCEPTED SOLUTION
LK_EXN
Hi.
1. No, you cannot do that. To configure a forward action to Zoom Contact Center, you have to select a Flow. If Flow does not have an external phone number assigned, then it's not visible in IVR configuration and you cannot save that setting.
2. Yes, you can have IVR (Auto Receptionist) extension without assigning any real number. I think that it should even have some number assigned by default to Main Auto Receptionist, but I don't remember that for sure 😅
5 REPLIES 5
LK_EXN
Hi.
Thanks for the reply. Much Appreciated.
So how can you dial an IVR internally ?
LK_EXN
As you can see on screenshot Auto Receptionist can have an internal number (extension), so you can dial it just like any other user.
In that example user just has to switch to Zoom Phone tab, dial 801 and that's it. He/she will hear a prompt assigned to IVR.
M_Ameen
Zoom Partner
Zoom Partner
How can you forward it to ZCC Voice flow without an entry point. Any Idea ?
LK_EXN
As far as I know there is no way  to achieve that right now.
You could leave a feedback to Zoom team and mention such feature:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0068808
