ZOOM Phone ライブ文字起こしを利用しています。
minoriman
通話中のライブ文字起こしを利用しています。
あとから、メモとしてメールに添付したりしたいのですが、ライブも文字起こしされたものがどこにも存在しません。
どこに保存されているのでしょうか?
通話中は表示されていますが、電話が終了すると画面から消えるのでなにもできないのです。
通話しながらライブ文字起こしされたものを見る意味はないと思われます。ライブ文字起こしされたデータを活用して、伝達の手間やミスが無くなるのではないかと期待をしていましたが・・・
誰か、ZOOM Phoneのライブ文字起こしのデータがどこに格納されているのか知っている方はいませんか?
1 REPLY 1
hi @minoriman ,
According to zoom, zoom phone live transcriptions are not stored anywhere.
Using call live transcription
Assuming you have turned on live transcriptions for the call and before you end the call, you could copy and paste the live transcription to a text or word processing document or an email.
Sample zoom phone test call using your question translated to English.  Before terminating the call, I did a copy and paste to ms word with these results:
“170296
00:02
This call is being transcribed.
00:15
We use Zoom phone live transcription. We are utilizing live transcription during calls.
00:28
Later, I would like to attach it to an email. As a memo, but there is no transcription of the live performance anywhere.
00:41
Where is it stored? Its visible during the call, but you cant do anything about it because it disappears from the screen when the call ends.
00:52
It seems that there is no point watching a live transcription While on the call, I was hoping that using live transcribed data would eliminate the hassle and mistakes of communication.
01:07
Does anybody know where the Zoom phone live transcription data is stored?”
If you have zoom phone auto recordings turned on, the audio is stored and can be accessed on zoom client, zoom phone under history.  When you access the recording, you will see zoom generate a transcription of audio recording to text.  Zoom appears to prohibit copying this transcription; however, you can download the audio and use some other voice to text software to do your own transcription.
