Uploading my own IVR Recording
Denisce
Hi there! Where do we manage our IVR recordings? I see AI options but not where I can upload our own instead of using AI.
1 REPLY 1
colegs
@Denisce - The first step is to upload you IVR recordings to the Asset Library.  Once they are there, Edit the IVR and you should see a label for the 'IVR Greeting Audio Prompt' at the top.  Select Edit and it will give you the option to select the audio from the Asset Library.
