Receiving external calls to my Direct number in Zoom | Community
  • October 28, 2024
  • 5 views
Hi. Recently I currently cannot receive external calls to my Direct number in Zoom, but I can call out. Is the system down?
    Best answer by Calvo
    Hi
    all zoom system are up and running and there are no issues for zoom phone reported you can check here:
    https://status.zoom.us/
    Does alle other numbers are working? Main phone number?
    You can check in your dashboard if there is anything you can see or open a case for your specific issue.
    Cheers
    CalvoAnswer
    Community Champion | Partner
    October 29, 2024
    Hi
    Cheers
    CarlaA
    Hi @tsbe! I just wanted to let you know that I’ve marked @Calvo's response as the accepted solution as I believe it answers your question. I hope it helps! If you have any more questions or need further clarification, feel free to ask.
