Starting July 10, 2024, customers must add their phone numbers to an approved 10 DLC campaign in order to keep using SMS/MMS capabilities on their numbers.
Register now for an upcoming 10DLC Enforcement Webinar.
Zoom AI Companion2022-11-16 12:59 PM
I'm new to Zoom Phone. I personally use an Android phone. When I add my cell phone # to my call handling, my phone will pop up when someone calls me, but I get the regular Android phone face and can't access any Zoom Options. If I remove my phone number from the call handling, my Android will ring, but there is no pop up and I have to unlock my phone and go into the Zoom App to accept it. Am I doing something wrong? My business partner uses an Iphone and it works perfect. Any suggestions?
Solved! Go to Solution.
2022-11-17 10:44 AM
Hi @TTX
Is there perhaps an option on the Android in the Settings for how Notifications for individual apps show? I use an iPhone and there is an option as to whether the a Notification should show on the Lock Screen.
I hope this helps!
2022-11-17 11:29 AM
If your phone has Battery Optimization features enabled, probably want to exclude the Zoom app from that as well so app is not put to sleep in a way that prevents notifications.
2022-11-17 11:29 AM
2022-11-17 07:45 AM
So the issue is that receiving calls on Android while the phone is locked is requiring you to unlock the phone first - correct?
2022-11-17 09:56 AM
Yes. When I remove my number in the Call Handling it will ring on my phone, but there is no pop up and I have to unlock my phone, open the zoom app, go to calls and then accept it.... If I have my phone number listed in the call handling, the call will pop up and ring and I can answer it without unlocking phone, but then I only get my phone screen with no zoom options. below is a screen shot of both
2022-11-17 10:44 AM
Hi @TTX
I hope this helps!
2022-11-17 10:55 AM
Thank you so much. I went into the app on phone and changed a couple settings. It is working perfect. Thank you so much.
2022-11-17 11:13 AM
Excellent! You're welcome!
Would you mind sharing which settings you changed so that others who have the same issue can find a quick answer!
Thank you,
2022-11-17 11:26 AM
Sure. I'm assuming by changing both is what made it work. I didn't change one and try and try the other one and try again. When looking at the Zoom App settings, It just looked like I needed to chane both...
I turned on the notifications and I also unchecked the box for "remove permission if app is unused". See picture
2022-11-17 11:29 AM
That seems logical to me.
Thank you so much!
2022-11-17 11:29 AM
2022-11-17 11:34 AM
Good idea, thank you so much. I just changed that setting to Unrestricted.
And for anyone that does not know how to do that. Go into your Zoom App, click on Battery and you have
3 options. Unrestricted - Optimized - Restricted
