Provision Template For Poly | Community
  • July 3, 2024
  • 36 views
Hi!
I am having problems with a provisioning template for my Poly phones. I am trying to use a provisioning template to assign a vlan to the phone, but have the PC Ethernet port assign a different Vlan for the PC I connect to it. Here is the template thus far:
vlan device.set="1"
device.net.vlanId.set="1"
device.net.vlanId="10"
device.net.lan.vlanId.set="1"
device.net.lan.vlanId="20"
In this example, the phone would be assigned VLAN 10, but the port should tag traffic from the PC port to 20.
Thanks!
July 12, 2024
hi mrjpr,
i am asking a few people about your inquiry.  they would like to know what switches you are using and a copy of your most recent provisioning template.
i asked chatgpt 4o questions on cisco discovery protocol and provisioning template, the reply is attached.
sometimes chatgpt responses are useful as a starting point.  i would suggest a review by a network expert.
you may also consider opening support tickets with zoom and poly.
