Phone number for voicemail access | Community
Tom
  • July 31, 2025
  • 5 views
Has anyone been able to come up with a solution for people to access their voicemail without using a Zoom client and/or adding the enable callers to check voicemail?  It would be nice to be able to call a phone number, enter your extension, enter your PIN and listen to your voicemail.
July 31, 2025
hi @Tom
it is pretty easy to check your voice mail by calling your phone number from any phone.
please see Zoom support article.
Checking voicemails over phone
is there a use case where you would like to call some other telephone number to get your voice mails?
July 31, 2025
hi @Tom , @ColtLester
this support article covers shared mail which may work for you.
Sharing voicemail inbox access
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0069406
Tom
TomAuthor
Unfortunately this option would not work either.
this feature only works if you dial your number and want to check by phone.  I've come across a scenario where we have a AR configured that forwards to user voicemail only.  If you attempt to dial the number assigned to the AR and the call is routed to user voicemail , no IVR ever prompts to check the mailbox.
