Phone System Queue | Community
Phone System Queue
  • January 10, 2024
  • 12 views
Is there a possibility to automatically log you out of the queue when going on DND (Do Not Disturb)?
Best answer by rauckenthaler
Currently, we are setting our "Do Not Disturb" (DND) status in the client, and in addition to that, we are disabling receiving calls from the call queue. We were informed that if we only set our DND without disabling receiving calls from the call queue, we would still receive missed calls. However, if you are suggesting that selecting either DND or disabling calls from the call queue both results in no calls being routed to our client, then it's an educational issue on our end.
I tried with my demo account to jsut set the DND status and i didnt receive calls anymore in the client. Have a try for yourself to see if you get teh same behaviour.
Or are you using desk-phones by any chance?
You can either set your DND in your client
or disable receiving calls from the call queue
Both will lead to no calls being routed to your client
DiankeAuthor
HI Rauckenthaler,
Yes, thanks, but the issue we are experiencing is that users forget to log themselves out of the queue after going on DND and I was wondering if there was a feature that would log you automatically out of the queue when going on DND. We have experienced that when a user is on DND and not logged out of the queue that they would still receive calls/missed calls which reflects bad on the call service level report.
Hello Dianke,
Can you elaborate more on what you mean by "after going on DND"? How is the user doing this?
If i set my presence status in the client to DND i dont receive any calls in the client. so am wondering what you are doing differently.
Hi @Dianke did you ever find the answer to your question? I have just observed what you are saying. Although, when you are on DND, you do not receive notification of the call, the queue still attempts to push the call to that user. You can see this information in the call log.
