Phone System Management Does Not Load | Community
  • April 24, 2024
  • 13 views
I've been trying to access the Phone System Management option for the last 2 hours, and it just shows the loading icon next to the menu option and nothing happens.
I have tried it from two different accounts and different browsers as well, but still nothing. The Chatbot was unable to be of any help.
There is an urgent setup that needs to be done, but it's being delayed due to not being able to access the menu.
Would appreciate if this is rectified.
April 24, 2024
hi najira,
i was able to access Phone System Management from zoom this morning from las vegas, nevada.  are you still having this issue?  if so, i suggest you open a support ticket.
najiraAuthor
Hi Eliot,
Yep it started working about an hour after posting this. I couldn't find the ticket area, hence why I posted here. But looks like things have resolved itself as such.
