Pagination with Poly VVX450 phone | Community
Partner
June 19, 2024
  • June 19, 2024
  • 24 views
Looking for the steps to expand buttons on Poly VVX450 phone from 12 buttons to 48 buttons.
June 19, 2024
hi bob1515,
i believe that you will need to install a vvx em50 expansion module.
please see attached user and admin guides.
Partner
June 24, 2024
Poly calls multiple pages Pagination. This can be enabled by creating a provisioning template to enable pagination.
Use the following parameter to configure pagination on VVX phones.
up.Pagination.enabled
Enable or disable the pagination feature.
0 (default) – Disable
1 – Enable
New Member
March 2, 2026
In my case with 3CX, you need to create an additional template based on the VVX GEN2 model and add:
<up up.Pagination.enabled="1" />
right after
<up up.screenCapture.enabled="1" />
around line 900.
