One Zoom Phone Number and 6 admins | Community
  • October 6, 2024
  • 1 view
Can all 6 admins use the same zoom phone at once?
jdott16
Hello   @Chelle1
From the description, it appears you may be looking to utilize either a Call Queue or Auto Receptionist. Though similar, the features are different and understanding them to fit your needs would be useful. I would recommend familiarizing yourself with the following documentation which should assist with this request:
I hope this helps and please make sure to mark the solution as accepted if this information is what you needed.
Thank you,
Jake
