2025-03-08 12:07 PM
I already have an business account running. I'm interested in porting another number, at the same time can it be used separately from my current account, meaning, the contacts and calendars do not comingle. While using the same Phone and workstation Apps.
Thanks!
2025-03-11 08:16 AM
Certainly. Zoom sign-on is email based. If you have a separate email account, you can activate a second account in Zoom and assign the second number to it. Your app however, will only allow you to login to one account. Use a second device if you want to login to the other account at the same time.
