Inbound calls Caller ID | Community
  • July 26, 2024
  • 18 views
Hello!
Our calls are coming as "Wireless Caller" and no number. Is there a change that we need to make?
Or is this intentional? How do we see the number before answering the call?
Thank you,
July 27, 2024
Hi NathanLao.
Common to all scenarios: caller's name and number
All inbound call notifications display the caller's name and number. The name and number will vary based on if the caller is internal or external:
Scenario
What's displayed in the inbound call notification
External caller
Internal Zoom Phone user in the same account
or
External Zoom Phone that been added to contacts
External Zoom Phone user
Note: If the phone number is in a synced contact, the synced contact's name will override the caller's caller ID name or Zoom profile name.
Sometimes callers suppress their caller ID number.  If this happens, Zoom may only know that the call came from a wireless carrier.  If you want to block calls without a caller ID number, you can do so.
How to block callers without a caller ID
Enable or disable Block Calls without Caller ID to block all incoming callers that hide their caller ID.
Account
  2. In the navigation menu, click Account Management then Account Settings.
  3. Click the Zoom Phone tab.
  4. Under General, click the Block Calls without Caller ID toggle to enable or disable it.
  5. If a verification dialog displays, click Enable or Disable to verify the change.
  6. (Optional) To prevent all users in your account from changing this setting, click the lock icon
    , and then click Lock to confirm the setting.
Site
  2. In the navigation menu, click Phone System Management, then Company Info.
  3. Click the name of the site you want to edit.
  4. Click the Policy tab.
  5. Under General, click the Block Calls without Caller ID toggle to enable or disable it.
  6. If a verification dialog displays, click Enable or Disable to verify the change.
  7. (Optional) To prevent all users in your account from changing this setting, click the lock icon
Phone user
  2. In the navigation menu, click Phone System Management, then Users & Rooms.
  3. Click the name of the user you want to block numbers for.
  4. Click User Settings.
  5. Under Others, in the Block List section, click the Block Calls without Caller ID toggle to enable or disable it.
Managing the blocked list (zoom.com)
thanks, eliot
