Forwarding Calls to Another User's Voicemail | Community
  • May 18, 2025
  • 3 replies
  • 25 views
Is there a way to transfer a call directly to another user's voicemail from a desk phone (we're using Cisco 8861s) even when they are not using their phone? With our previous provider, we were able to key a zero before the user's extension and it went directly into their voicemail rather than ringing their phone line. I am hoping that this is a possible feature with Zoom, as well.
Best answer by Eliot
hi @Kristin_GF
it is a little more difficult with cisco desk phones.
You can use DTMF keys on your Cisco phone to transfer a call to another user’s voice mail.
While on a call, select the three dots
On the next screen, select BlindXfer
On the next screen, enter **(extension), i.e. **800 to transfer the call the extension 800’s voice mail and Call.
The Zoom desktop client / mobile app, Yealink phones, and Poly phones have menu options for this, so there's no need to use the DTMF code.
For more details, please see Zoom support articles below.
Using and customizing DTMF codes
Transferring calls
thanks, eliot
sparrow
May 19, 2025
You can do that via the Zoom app, but with desk phones, there is no documentation on how that can be accomplished that I was able to locate.
EliotAnswer
May 19, 2025
hi @Kristin_GF
Transferring calls
thanks, eliot
You're my hero! Thank you!
May 20, 2025
hi @Kristin_GF
nice to hear that my suggestion worked for you.
you may be interested in what features on your cisco desk phones are supported by zoom.  please see
Supported desk phone features
