Enable ConnectionServices where is it? | Community
  • November 28, 2023
  • 10 views
I use Zoom for the softphone for work.  I also use hearing aids.
Since my audio device is a hearing aid and not a headset, for the android zoom app to use my hearing aids as the audio out I have been needing to Enable ConnectionServices. (More>General>Enable ConnectionServices) because for some reason the app does not just use the default system settings.  in the latest update this option is no longer there.
I have searched all around the app for this setting to see if it has been moved but it is not anyplace I can see.   I really do need this option to function.
Thanks!
dubhcaoraAuthor
bump.
crickets from zoom on this.
not even a canned nothing response.
dubhcaoraAuthor
bump again.  can i get a canned nothing response at the minimum?
