2022-02-24 02:47 PM
I have three questions.
Is it possible to set the Polycom Vx250's so that an external incoming call is DND but the incoming internal calls still ring the phone?
Is it possible to set a Polycom Vx250 that when it receives an internal call it answers automatically on speaker?
Is it possible to intercom multiple Polycom vx250's at one time?
I know an Avaya system can do that, I'm hoping this can as well.
Thanks for any help
Teresa
Solved! Go to Solution.
2022-03-01 05:49 AM
Is it possible to set the Polycom Vx250's so that an external incoming call is DND but the incoming internal calls still ring the phone? - this is not possible for VVX phone but you can Block external calls by going to a user profile>user settings>others>toggle block external call then toggle it off again if needed( this can be achieved by logging in to the account using a browser)
2022-03-09 01:29 PM
If my reply solved your discussion don’t forget to mark reply as the solution. Thanks!
2022-03-01 05:49 AM
2022-03-09 01:29 PM
