2024-11-26 10:53 AM - edited 2024-11-26 10:54 AM
What is the easiest way y'all are reporting your call volume per person/department? On prior systems we were able to determine the answer ratio but I am not having the best luck with the zomm analytics.
2024-11-27 03:31 AM
You would need to log into the Zoom web portal as an admin....then head over to Analytics & Reports and choose "Call Queue Historical Reports".
Under the Detail Report tab, you can customize your view by selecting specific sites or departments from the drop-down menus at the top.
2024-12-04 09:25 AM
I recall analytics and reporting requires power pack licensing. Without that, the user will not see this option.
2024-12-02 12:46 PM
Hi @rkey, thank you for posting in the Zoom Community! If you found @FarioConsulting's reply helpful please mark their reply as an accepted solution so others in the community may easily find their answer 🙂
Thank you!
