Call Forwarding Fee Question | Community
  • July 10, 2024
  • 48 views
On my company's plan, I have a user who very rarely uses her number and would only occasionally get inbound calls. I want to forward her phone to her cell, however when I try, I notice it says "I acknowledge that calls forwarded to the PSTN may be billed based on usage, per the terms of my calling plan". I'm not privy of which tier of plan the org has, but we have a toll free number, a decent number of users, etc.
I tried reaching out to customer support to get clarification on this, but the slow responses are as clear as mud. I'm just trying to find out if there's a fee for forwarding, how much is it?
I get my own calls forwarded occasionally when I am not at my desk to receive them, however they don't last more than 1-2 minutes. When I set up my own call forwarding 2 years ago, I don't believe I saw this same verbiage on it. I definitely would have thought twice.
TL;DR: How much is the fee for call forwarding if there is indeed a fee?
Thanks in advance.
July 10, 2024
Welcome to the Zoom Community, @Sheebs.
There is no fee specifically for call forwarding. It’s just a warning that if the number you enter to be forwarded to is not a number covered by an unlimited call plan, you are “hereby warned” that you’ll potentially be charged as if the company made the call directly, in my way of putting it. Bottom line: it doesn’t wait for you to enter a number, check it, and then maybe display a warning; plus, you might charge calling plans.  “Don’t say we’re didn’t warn you.” 😎
I’m guessing it probably warned you when you set up your forwarding. If not, it probably should have.
SheebsAuthor
Hi Ray,
Thanks for the reply! Let me try to rephrase this in the way I'm understanding it, and you can let me know if I'm off base.
So the forwarding itself does not have a charge, but the phone picking up will be charged if there's no unlimited plan.
Is that right?
July 10, 2024
Let’s define the 3 phones involved:
  • A: The original, external caller
  • B: The internal number being dialed
  • C: The external number being forwarded to.
If by “phone picking up” you mean the B, yes. Your company might pay for but the call, since it’s doing the forwarding.
