Volume (input and output) too low on Mac - All settings are on and set to Max Volume | Community
  • March 25, 2022
  • 5 replies
  • 99 views
Using an iMac with Monterey upgraded March, 2022 my input and output volume too low for me and my participants. I have double checked that all audio settings both for Zoom and my Mac are on with the correct mic and speakers (default system)  and set to Max Volume. The volume issues are corrected (sort of) when I pop in my AirPods. HOWEVER,  the AirPods do not work for audio (mic or speaker) they simply kick my iMac speaker and mic into "on" (or more functional?). HOWEVER AGAIN, I then cannot adjust the now MAX volume down using either Zoom or my Mac volume controls. This started *I think* about a week ago with the latest Mac OS 12.2.1 update. Previously, I had zero issues and have been adjusting mic and speaker volume when in Zoom just fine. This problem is ONLY with Zoom. I do not have this issue with other video host apps (FaceTime, Google Meet, Teams, music, etc.).
IP-Man
@KAlstrin
You may need to do a clean uninstallation of your Zoom client to resolve this issue.
If you have a Mac -  try uninstalling Zoom by using their uninstall file instead of putting the Application in the trash.
You can do this by going to Applications -> right clicking on zoom.us -> Show package contents -> open Contents -> open Frameworks -> use the ZoomUninstaller file.
After this, try to reinstall Zoom again.
Hope this helps.
KAlstrinAuthor
It also happens when using Zoom through the web host (not the app).
IP-Man
@cnancyc , could you please  hit accept the solution on the solution that solved your issue so that others in the community may benefit as well.
IP Man, I don't see where I can "accept the solution".
cnancyc
IP-Man
@cnancyc
Hope this helps.
KAlstrinAuthor
This appeared to work temporarily. Although, there was not an uninstall file anywhere in the Zoom package client folder. When I turned on Team Viewer Quick Support to view my client’s device (Braillenote) the problem resumed. Glad your solution worked for someone else. However, as the original poster, the problem is not resolved!
