Sound distortion when playing musical instrument | Community
  • September 15, 2024
  • 0 views
When I play a musical instrument during Zoom lessons, the sound comes out distorted. "Choppy" is the best way I can describe the problem.
I am on a Dell Inspiron 14 laptop, Windows 11, Zoom version 6.1.11. I am able to record video and audio from my laptop camera without any issues. My Internet connection is via Ethernet cat 5 E, so upload speed is not a factor.
My Zoom settings are optimized for musicians and are exactly the same as those used by my teacher and classmates. They're also the same as the settings I used on my older Acer laptop, which worked fine.
I tried an experiment by doing a Zoom meeting with myself from my husband's older Dell using all the same Zoom and Dell settings and the same versions of Windows and Zoom as mine. My playing came through just fine over his laptop.
Both laptops use Realtek Audio with one difference. His runs a driver version from 2021; mine runs one from 2023.
Could my distortion issue be the result of a conflict between the Zoom app and my microphone driver? Should I try to replace my driver with the older version?
Best answer by OboeSally
Update to my previous post: The problem relates (in a way I don't understand) to the way the Realtek microphone array processes signals. It's great for voice but really terrible for playing music over Zoom. I went into the microphone array properties and unchecked the "Enable audio enhancements" box. That fixed the problem.
OboeSallyAuthorAnswer
