Problem when Zoom Does Not Find Microphone and Speaker
bsfinkel
I had a problem yesterday at a Zoom meeting.  I was using a laptop in the same room as the presenter.  I have done this many times without any problems.  I have a headset with a microphone connected to the laptop.    When I was let in to the meeting, for some unknown reason Zoom did not detect my speaker nor microphone.  (And i did not know that until I was let in to the meeting.)   But the laptop was causing echo in the Zoom meeting.  There was no way that I could mute my session because, as Zoom did not recognize my microphone and speaker/headphones, it did not provide me with a mute icon.  This has never happened before, and it did not happen when I just tested the laptop and headset with another Zoom session.  I have no idea why Zoom did not sense my microphone and headset.  But I consider it a bug that Zoom did not present me with any way to mute.  I had to disconnect from the Zoom session.
2 REPLIES 2
FarioConsulting
Contributor I
Contributor I
Could you try clicking the "Join Audio" button, then selecting "Join with Computer Audio"...and see if it helps
Harsh
We help businesses with Zoom integrations, customizations and setups
Reach out and learn more on Fario Consulting
IF it happens again, I will try your suggestions.  This has happened only once, and I had to time to do any testing because my Zoom login was causing echo for everyone else in the session.  I was hoping that someone from Zoom would be3 monitoring this forum and see my report.
