Need help on speaker/microphone | Community
  • December 12, 2024
  • 4 replies
  • 3 views
I have a Basic Plan with Zoom.   I use a Microsoft laptop.   Our investment club meets in person in a physical room, with 1-3 other members joining via Zoom.   To enhance audio and microphone for those on Zoom, we have purchased a 3 microphone/speaker product which connects into the one port in my laptop.    However, only one microphone/speaker works at one time.   In Settings, I am able to switch between microphones/speakers, but only one works at a given time.    What do I need to do in Settings so that all 3 work at the same time?
    Best answer by numbersguy49
    Thanks!    I believe I have a solution.
    bstrelko
    What you are attempting to do is not natively supported by Zoom as of this post. Zoom Workplace Client only supports a single audio device as an audio input and a single device (can be a different device) as an audio output.
    You will need to use some type of 3rd-party software to use all three at once on the same PC.
    On Mac, you could configure these as an aggregate device via audio-MIDI settings.
    On Windows, you can use software like Voicemeeter (https://vb-audio.com/Voicemeeter/banana.htm - 'Banana' version supports 3 inputs). You will need to know what you're doing, as this is a very complex application for users who are not familiar with digital audio routing.
    December 18, 2024
    You need to use an audio interface that will mix the 3 mics to one output that goes over the USB connection. One such device is the Focusrite 18i8 or the Zoom AMS-44.
    bstrelko
    Are you able to provide the make/model of the audio device you're using?
    numbersguy49AuthorAnswer
