Celebrate with us2024-10-15 01:37 AM
Hello Zoom team I want to use your software for the organization I work for, for online meetings, but the problem is that it must be connected from the phone through the software, and it cannot be done without it. I wanted to ask if there is any way for this to happen through the web, it is easier. Thank you for your help please
2024-10-15 08:05 AM
Hello @soheileghbali
Your request appears to be a bit vague. Would you be able to provide a more detailed request so we can see what we can to do accommodate this? If you would like to reach out to Zoom Support for further analysis and investigation, you can find out more on reaching support here: https://support.zoom.com/hc/en/contact?id=contact_us.
I hope this helps and please make sure to mark the solution as accepted if this information is what you needed.
Thank you,
Jake
