2023-08-17 11:49 AM
Does anyone know if it's possible to click an object and drag it using the blue remote control mouse in meetings?
Solved! Go to Solution.
2024-09-07 05:13 AM
i found that in order to be able to pick up and drag, user has to hold down the object for 2 seconds before moving according to this video.
https://www.youtube.com/watch?v=OJww5XNZb8I
2024-09-07 05:09 AM
Have you found a solution yet ? i have the same problem.
2024-09-07 05:13 AM
2024-09-13 01:44 PM
Hi @nadzap!
Did you see the previous response from @MoHammad_B?
Have a great day!
2024-09-27 12:09 PM
Hi @nadzap!
Given the time elapsed since we last heard from you, I've taken the liberty of marking the provided answer as the solution.
Have a fantastic day!
2024-09-14 04:49 AM
Hey @nadzap! Yes, you can usually drag and drop objects using the remote control mouse in meetings, but it depends on the platform you're using. If you're on Zoom, for example, the remote control feature should allow you to click and drag objects as if you were controlling the host's mouse.
