Darshan HIranandani : Mute/Unmute AirPods Pro Control Not Working in Zoom on Mac – Any Fixes? | Community
  • January 13, 2025
  • 29 views
Hey everyone,
I'm Darshan Hiranandani, I’ve run into an issue when using my AirPods Pro to mute and unmute myself during Zoom meetings on my MacBook. When I press the call control button (one press by default), I receive the error message, "Can't control mic with AirPods Pro." It works just fine when I use my AirPods Pro with Zoom on my iPhone or iPad, but not on my Mac.
Has anyone encountered this problem and found a way to get it working on a Mac? I really rely on this feature for productivity, especially when the Zoom window is out of view, and it’s difficult to unmute quickly.
Any suggestions or advice would be greatly appreciated!
Thanks so much!
Regards
Darshan Hiranandani
Hello Darshan my name is Megha. This issue arises because the macOS version of Zoom does not currently support the AirPods Pro’s call control button for muting and unmuting. While it works seamlessly on iPhones and iPads, this limitation is specific to Mac. A workaround could be to use Zoom’s keyboard shortcuts (e.g., Shift+Command+A to mute/unmute) for quick mic control on Mac or check for updates in both Zoom and macOS that may add support in the future. Additionally, ensuring your AirPods Pro firmware and macOS are up-to-date might help if updates include related fixes.
Just wanted to chime in that this feature actually worked until about a week ago, when I updated both my macos to Sequoia 15.3.1 and zoom to 6.3.11. So one of these updates (or maybe both?) broke the feature.
EDIT: see @germann's comment below - you can download the older version directly from Zoom servers:
ARM64 (Silicon macs) https://cdn.zoom.us/prod/6.2.11.43613/arm64/zoomusInstallerFull.pkg
Intel (older macs) https://cdn.zoom.us/prod/6.2.11.43613/Zoom.pkg
My hero
Hello there,
Welcome to the Zoom Community! We do apologize for the inconvenience.
As per our engineering team, we did support this feature in the past, but due to some user feedback indicating that it was easy to trigger mute/unmute on the AirPods accidentally, we disabled this feature again in version 6.3.0.
In the future, we plan to add a sub-option under "Sync buttons on headset," along with clearer instructions, and then re-enable the feature, allowing users to choose whether or not to sync the button functionality on AirPods.
For now, thank you for your patience and understanding.
Same problem here. It used to work fine in the last month or so. Not anymore. Any suggestion?
I'm on ver 6.4.6 on MacOS
Hello @jojojo3632! Can you kindly try uninstalling and reinstalling the latest version? Let us know if it helps or if you need further assistance.
