Response of zoom AI is not relevant with my info.
I'm using Zoom AI Companion solution. However, It generate response regardless to my situation. Is it possible to make response regarding to my data? For example, a sentense which I use frequently also called 'template' should be reflected to response AI generate. I want to get response which is relevant to my past data. it is called ..... Tuning?
