Zoom pro can only audio conf in 3 people not 10
dylanhunt
Attendee
The user has a pro lic, but they can only conference in 3 people.
Anyone seen this before?
the zoom faq's say 3 for basic and 10 for pro.  I have a ticket open with support about it also .
2 REPLIES 2
FORE-Craig
Hi @dylanhunt
I believe that you need to contact Zoom Support to enable Multi Party Conferencing feature for more than the standard 3-way call.
You can submit a support request at https://support.zoom.us/hc/en-us/requests/new
I hope that helps!
Craig
dylanhunt
Attendee
It helps, but doesn't seem like TS can get it to work. My poly vvx-350 can only do 3, but soft client can do more than 3. I don't understand why this isn't enabled by default on all accounts. the 3+ only works if you have pro lic.
