Pop up not happening while phone ringing - Cannot answer incoming call | Community
  • August 1, 2022
  • 37 views
This has been happening for several weeks now.  My cell phone (while away from my desk) will vibrate to all get out -- but no pop up appears that allows me to answer the phone.  So any incoming call on my Google Pixel just rings until it goes to voicemail.
I haven't tested this theory yet, because it seems implausible, but is this happening because it is not on WIFI?
I have just uninstalled it on my phone to alleviate the frustration.  If there is a fix or answer, I'll reinstall, but this isn't worth the anxiety knowing I am missing a call, but have no way to answer it.   It's mocking me, LOL.
    Contributor I
    August 4, 2022
    Are you saying the Zoom app doesn't show a popup? If so, I did run into once someone on an android phone that had a similar issue that was caused by some kind of gaming enhancement app that manipulated notifications (presumably to reduce interruptions during gaming).
    Same issue was it ever resolved?  No gaming
    Welcome to the Zoom Community, @bstoker! If you are using an Android device, you can try these steps:
    • Ensure Notifications Are Enabled:
      • Go to your phone’s Settings > Notifications > Zoom.
      • Make sure Allow Notifications is enabled and that banners, alerts, and sounds are all turned on.
    • Allow Zoom to Show Over Other Apps (Android only):
      • Go to Settings > Apps > Zoom > Appear on top (or “Draw over other apps”).
      • Ensure this permission is enabled so Zoom can display call pop-ups.
    • Enable Background App Refresh/App Activity:
      • Ensure Zoom is allowed to run in the background so it can trigger incoming call alerts.
    • Check Zoom App Settings:
      • Open the Zoom app.
      • Go to Settings > Meetings > Incoming Call Notification and make sure it is turned on.
    • Update Zoom:
      • Make sure you are using the latest version of the Zoom app. Visit the App Store or Google Play Store to check for updates.
    • Restart Your Device:
      • A quick reboot can sometimes resolve notification issues.
