Outgoing caller ID showing wrong number on desk phone | Community
  • August 26, 2023
  • 3 replies
  • 0 views
Recently I noticed the outgoing caller ID on my desk phone is not showing the correct number from my settings. It's using the main company number which is toll-free. The Zoom desktop and mobile apps show the correct caller ID. Any ideas on how to fix this? Desk phone is a Poly VVX450.
Best answer by Eliot
hi chrisjohns,
assuming your admin allows you to change desk phone keys and positions,
go to your profile->personal->phone->settings->desk phone->keys and positions->view or edit->manage key.
select outgoing caller id same as number
EliotAnswer
August 26, 2023
hi chrisjohns,
Hi @Eliot ,
Do let us know how we can show the caller ID of Call queue or AR,  as We wanted to display the same outbound caller ID or 5 digit caller ID for internal 5 digit extension calls also.
i.e for internal Zoom phone call within organization.
Note – We are trying to change the caller ID on Desk phone\Common area poly phone.
I have a question. Under the user's Zoom Phone account, I set up the Outbound Caller ID to a specific number, which is different from the user's direct number! When I call out from this user externally, the number I set up does not display, and it still shows the user's personal direct number.
When I go to your profile -> personal -> phone -> settings -> desk phone -> keys and positions -> view or edit -> manage key, and change the Caller ID there, it works. Why is this so confusing? Why can't I change the caller ID from the user's profile?
Also, I work for a mid-size organization, so I need to change this caller ID for all users. How can I do this via a mass update to reflect in the section: "go to your profile->personal->phone->settings->desk phone->keys and positions->view or edit->manage key"?
July 23, 2025
hi @netadmin
Hard to believe but some Zoom Phone customers only use desk phones and assign outbound caller id under user settings, desk phone, keys & positions.
If your organization is using Zoom Workplace apps, then you assign outgoing caller ID to the user profile, outgoing caller ID.  This setting also seems to over-ride keys & positions settings on desk phones.
Admins can control whether users can change their outgoing user ID.  Go to account management, account settings, Zoom Phone,  Select Outbound Caller ID (enable or disable).
I did not see any place to make account level changes to outgoing caller ID.  You might discuss this your Zoom account team and or Zoom Support.
Please see:
Frequently asked questions about caller ID
Changing Zoom Phone policy settings
Changing phone settings (web portal)
