Incoming calls go directly to voicemail. Can't leave a message | Community
  • January 5, 2023
  • 5 replies
  • 2 views
All inbound calls go directly to voicemail and the voicemail message keeps repeating.   I cant receive inbound calls and clients cant leave a message.
Very frustrating.
    FORE-Craig
    Specialist
    Specialist
    January 6, 2023
    Hi @EdGol
    All of the settings for handling your calls are setup in the Phone > Settings tab of the Zoom Web Portal at https://zoom.us/pbx/page/telephone/myZoomTelephony#/my-cloud-phone/settings
    Scroll down to Business Hours and set the parameters for Call Handling, you should also set the parameters for Closed Hours the way that you would like them.
    I would suggest that you walk through the Getting started with Zoom Phone (Users)
     AND if your are the owner/admin of the Zoom Phone Account, you should first read the Getting started with Zoom Phone (Admin) .
    You will gain a lot of knowledge on the hierarchy of the Zoom Phone as well get links that describe how use/setup  the basic and advanced features.
    I hope that helps!
    EdGolAuthor
    Thx, Have done that. Business hours set at 24/7, for admin. and user (single user). Call handling set at 24/7 as well.
    FORE-Craig
    Specialist
    Specialist
    January 6, 2023
    You're welcome, @EdGol
    So, are you the only person using the Zoom Phone System? Do you have the Auto Attendant with the Main Company Number transferring to your extension in the Call Handling?
    The Main Company Number does not work with SMS.
    https://support.zoom.us/hc/en-us/articles/360040413932--Frequently-asked-questions-about-SMS
    You could add an Additional Number to your account subscription, I think it is around $5 a month. You may also be able to Unbind the Main Company Number and assign it to your Profile, if that is the number that people are used to using to contact your by SMS.
    I hope that helps!
    Contributor I
    January 6, 2023
    If you call one of the extensions directly from Zoom app, do you have the same issues?
    EdGolAuthor
    I only have one line and one extension (800).  The auto attendant is extension 801.
    I have the same issue.  Single user.  When I try to forward to my extension 800, my name populates in the drop down, but it is shaded gray and won't let me click on it.  It also doesn't tell me why.
    M
