HD video and audio collaboration
Integrations and bots to use with Zoom
Full-featured, easy-to-use, engaging webinars
Enterprise cloud phone system
All-in-one platform to host virtual experiences
Connect your teams and streamline communications
Power up your conference rooms with video
APIs & SDKs to extend and enhance Zoom
Supporting a Hybrid-friendly Work Environment
Explore products and tools for seamless collaboration across office and home working spaces.
Discover new ways to use Zoom solutions to power your modern workforce.
Access expert-led tutorials on Zoom products and features.
Network with other Zoom users, and share your own product and industry insights.
Get documentation on deploying, managing, and using the Zoom platform.
Keep your Zoom client up to date to access the latest features.
Download CenterDownload hi-res images and animations to elevate your next Zoom meeting.
Browse BackgroundsDiscover new ways to use Zoom solutions to power your modern workforce.
Browse BackgroundsWhat's New at Zoom? Join our upcoming webinar to get a first-hand look into some of our exciting new product and feature releases.
Register Now2022-04-29 11:03 AM
Our service and porting was completed today and all our phones are installed and working. Our call queue was setup by Zoom support a couple weeks ago so that 4 desk phones would ring when we received a call to our main number.
This is good, however, even the mobile app associated with users at those 4 desk phones will ring which is not good. We only want the mobile app to notify a user if we transfer a call to them.
Is this possible? I also remember reading that the Zoom mobile app has a "DND" feature that would only affect the mobile app. We cannot find "DND" on the mobile app, but in SETTINGS -> PHONE there is a toggle for Receive Queue Calls and MAIN LINE (our queue). If they switch that off on the mobile app, it also keeps their desk phone from ringing.
Summary (I hope) of what we want/expect:
1. Inbound call to our main number to ring desk phones in our office - users that we select. Do not ring or notify the mobile apps.
2. If we transfer a call to a user extension, ring their desk phone then (sequentially) ring their mobile app.
Is this possible to setup on our admin side, or will they just need to log out of the mobile app when in the office and log in when leaving?
Thank you,
Mike
Solved! Go to Solution.
2022-05-02 09:27 AM - edited 2022-05-02 09:28 AM
They can setup to not receive calls on their Zoom App under their user settings>call handling> and toggle off the Zoom application switch.
If above does not meet your expectation, DND can be set on the mobile app under chat settings>do not disturb. If you do so, that will also apply to phone calls to mobile app(i.e only desk phone will ring and skip the mobile app)
2022-05-03 10:27 AM
Hi Mike,
Are your desk phones Zoom Phone Appliance models? This would explain why toggling off the Main Line Call Queue in the Zoom Mobile app causes the user's desk phone to not ring for Call Queue calls.
2022-05-02 10:43 AM
Thank you for the reply @IP-Man !
If we toggle off the Zoom application under user settings > call handling, they will not receive incoming calls or calls to their extension, correct?
I'm trying to find the best combination or workaround so that their desk phone rings on incoming calls, but not the app - because they are here. When they leave to go to a jobsite, I do not want them to get all the incoming calls on their app but can still use the app - for instance, if we need to transfer a call to them out in the field/jobsite.
It does not look like it can be done. The app is either ON or OFF/DND and OFF will ignore all calls.
2022-05-03 10:27 AM
Hi Mike,
2022-05-03 11:47 AM
They are the Poly VVX 450 and VVX 250
2022-05-04 05:15 AM
Thanks Craig. That made me think about it some more. If they are away from their desk, it doesn't have to ring and it silences the mobile app as well. As we found out this morning, this setting still allows us to transfer a call to their extension but they do not receive all inbound calls.
2022-05-04 07:37 AM
You're welcome, Mike! Yes, you can always receive a direct or transferred call in the app if you're logged into it. 😊 You were probably thinking about it from the opposite angle, and didn't realize that you already had the answer.
2022-05-04 05:12 AM
I believe we solved this issue. When away from their desk, the mobile app setting for phone "Receive Queue Calls" will affect calls to their desk phone and mobile app, which is fine because they are not at their desk anyway. But, as we checked, they can still receive calls transferred to their extension - so we can reach them in the field still.
When they return to their office, they can re-activate the "Receive Queue Calls" and be back in the queue.
