Discover Zoom success stories and upcoming events! Explore our Customer Success Forum & Events page.
Visit NowEmpowering you to increase productivity, improve team effectiveness, and enhance skills.
Zoom AI Companion2022-09-12 04:55 PM
Hello, we are using the system for a week and can't identify which line is ringing in the phones.
Any help here will be appreciated.
Thanks,
Alex
Solved! Go to Solution.
2022-09-13 05:48 AM
zoom has a quick start guide for yealink phones.
Quick start guide for Yealink T4/T5 series – Zoom Support
according to the guide:
During an incoming call, you will see a call notification with the caller ID name and number. The call notification on Yealink phones appear the same regardless of whether the call was routed through your direct phone number, main company number, or a call queue you're a member of.
Note:
2022-09-13 05:48 AM
Note:
2022-09-15 10:03 AM
