how do i turn off participants join sound (doorbell) when i'm not host or co-host? | Community
  • April 26, 2023
  • 12 replies
  • 570 views
i found it's very disturbing to me when i need to listen to it hundreds of times in big meetings.
    Login to zoom.us and Under Personal -> Settings -> Meetings, turn off Sound settings.
    KayaVangAuthor
    that does not work. I was also informed by your help chat that only works if i'm host.
    how do i turn off participants join sound (doorbell) when i'm not host or co-host? i found it's very disturbing to me when i need to listen to it hundreds of times in big meetings. Hi, Login to zoom.us and Under Personal -> Settings -> Meetings, turn off Sound settings.
    Regards,
    Will
    KayaVangAuthor
    are you referring to this? If you do, that does not work. I was informed by zoom help chat that this only works if i'm host.
    Hi @KayaVang @willjoe2442
    Yes this feature for the meetings you host. So, Please ask hosts to turn off this feature or customize it so only they can hear the sound notifications.
    Solved: you need to open the Participants panel in the Zoom meeting itself. Then click on "more" and there you can disable the "Play Join and Leave sound". Super annoying.
    KayaVangAuthor
    thanks for sharing. unfortunately only host can see that option.
    Yep came here from a google search, looking for an answer to the same problem, seems like zoom just doesn't support this for whatever reason.
    This is beyond irritating. I want to turn off ALL notification and dings as a default. I'll turn them on if I need them. I am changing all of my meeting to Teams simply for this reason.
    KayaVangAuthor
    lucky you, i schedule all my meeting on Teams too however don't know how to convince colleagues to do the same...
    Zoom, please add this feature or open source your software so someone else can. This is extremely distracting to some of us.
    KayaVangAuthor
    i'm so happy someone else has the same opinion. i've submitted numerous feedback to zoom already.
    I came here looking for this feature too. Something so annoying and yet they don't have an answer.  At least I can stop looking for it.
    It is beyond annoying that a guest cannot turn off the chime. The chime for guests serves no useful purpose.
    It's been a year now, and still no updates, Zoom? I guess we're switching to Teams. What an annoying feature to frustrate your customers with
    Is there already any update on this? I need to host meetings where I hear it when someone is joining, but without any of the others in the room hearing this. Why is such a simple feature not possible?
    Why is this still an issue in 2025? Can this not be added to the user settings at the attendee level? I do not want to hear the notification and I am not going to ask every single host to disable it.
