Mic on Laptop does not work but works in Sound Settings | Community
  • March 9, 2022
  • 1 view
I have had an issue with my laptop (that I have been using Zoom on for a long time).  Recently the built in Mic stopped working.  I checked the settings in Win10 and it is properly selected there as well as in the Zoom App.  When I look at the Mic in "Sounds" on the Win10 settings, I see the Mic working.  When I Test the Mic in the Zoom app it does not work.  I have the proper Mic selected, but notice that the slider next to the mic on the Zoom app does not move and it is set to minimum.
I fixed this once, by re-installing the Zoom software.  When it failed again, I tried the same thing and that did not fix it.  Rebooted, etc, to no avail.
I saw another post here about permissions and see that  everything there looks ok too.
Any ideas?
Thanks, John
    Hi
    I am having the EXACT same issue.  By now, I assume you solved it. Do you remember how?
