Where do Zoom Events Surveys display? | Community
  • April 5, 2022
  • 0 views
I set up surveys for my Zoom Event both at the event level and at the session level, but I do not know where they actually show up when the session is over. Can anyone point me in the right direction?
    Best answer by Happytohelp123
    @jchristiewilson  You're most welcome! Surveys are triggered automatically according to the agenda that the Host creates. These Session Surveys/Event Surveys can be shown to attendees at the end of a session, or at the end of an event. To configure survey details, visit the 'Advanced Options' tab when editing your Zoom Event.
    @jchristiewilson
    Here are the steps for accessing surveys:
    You can find your survey results in the Survey tab of Zoom Events registration management.
    1. Access the Host Analytics Dashboard.
    2. Click the Survey tab.
    In the Survey tab, the number of surveys for your conference event will be displayed. To the right of the number of surveys is the Export button, which you can use to download and view your conference event’s survey reports.
    Under Conference/Session Name, the event survey name and session survey name(s) will be displayed. By those names, you can click View Response to view each survey’s responses.
    Export survey reports
    1. In the Survey tab, to the right of the number of surveys, click the Export button.
      A CSV file of your survey reports will be downloaded.
    2. View your survey reports in the CSV file.
    Your CSV file will separate your survey results by session names in a conference event. For surveys, the CSV file will display the following:
    • User email
    • Survey question
    • Survey question responses
    • Additional comments (if applicable)
    Thank you so much! Very helpful. Can you tell me where attendees see the survey while logged into the session?
    Thank you so much for you help! I think we are now all set.
