Zoom Room - Can't join private meeting from controller | Community
  • January 24, 2022
  • 3 replies
  • 1 view
We don't have the ability to 'Join' a private meeting in a Zoom Room from the controller as we do with a public one. We've recently setup a new environment and our users indicate they were able to do so before. Is this an issue with permissions somewhere that I'm missing?
    Best answer by daveflexion
    Actually Google Calendar. I've managed to solve the issue. It ended up being that I had added the Zoom account as an admin on the calendar however I neglected to change the permissions for it to 'Make changes and manage sharing'. Because it only had 'View' permissions it wouldn't let me do anything. This is working now. Thanks for you help!
    nancyc
    Hi daveflexion,
    Is the "join" button missing completely?  Or is there an error message?  There are two ZR related settings around private meetings, but they do not inhibit a User from going into the room and joining.  (Unless the ZR is asking for a password?)
    I've attached a screenshot for you to check the status of the private meeting settings in the ZR.
    Please let me know if this has helped.
    Thank you!
    Thanks for the response Nancy! The option to Join just doesn't appear on the controller (which is a Polycom Trio 8800). It simply shows private meeting and then the time. I did chck those settings and we only have the second option enabled to hide details when it's a private meeting
    nancyc
    Hi Daveflexion,
    Are you using O365 calendaring for your Zoom room?  This happened to me when I configured mine as the powershell commands did not work the first time.  Please check out this support doc for clarification.  Setting-Up-Zoom-Rooms-with-Office-365
    Thank you,
    daveflexionAuthorAnswer
    nancyc
    So great to hear, Dave!  Glad it worked out.
    Thanks,
