Settings Menu -> General: very narrow content pane and the scrollbar in the middle covers the conten | Community
  • May 22, 2025
  • 13 replies
  • 13 views
Dear All,
Perhaps somebody has experienced such of situation already:
Under the Zoom Workplace for Linux, I have a problem with the window width in the Settings menu -> General. The content pane is very narrow, and the padding width on the right almost covers the entire content pane area. I cannot insert the picture here to show the issue, but I hope my description is clear enough. Perhaps you know, how to fix it? It is about version: 6.4.10 (2027)
We have identified the root cause, that is, some regions use comma (,) rather than dot (.) as the decimal separator, which causes the program to fail. The workaround is to temporarily switch the system locale to an English region. We plan to fix this issue in zoom client version 6.5.0 which is scheduled for June 15th.
Hello community members,
We're sorry for the inconvenience and thank you for your patience.
Kindly try updating to the latest version 6.4.12 were issues with the UI has been addressed.
As I previously posted in this thread, it's not fixed in either 6.4.12 (2180) or 6.4.13 (2309).  Hopefully the July 15 update fixes this.
Thanks for the workaround, DalongChen.
